ElecTech Posted March 11, 2016 Posted March 11, 2016 What do the regs say about green break glass units on fire doors, are they needed if the fire alarm opens the door through a I/O unit? Or do they have to be present at all times, I was under the impression they had to be present as a manual override. A new site we looked at today only uses fire alarm as the override. Cant be right...? Say the emergency isn't fire related, or perhaps in this day and age a terrorist related attack, people may still need to use this route as an exit. I marked it down as a issue we need to look at rightly or wrongly... Quote
Nova-Security Posted March 11, 2016 Posted March 11, 2016 The are classed as Emergency Door Release, nothing to do with fire. As you stated if the door needs to be used in an emergency what do they do. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
ElecTech Posted March 11, 2016 Author Posted March 11, 2016 The are classed as Emergency Door Release, nothing to do with fire. As you stated if the door needs to be used in an emergency what do they do. Nice one... So having said that, is it a REQUIREMENT for the fire alarm to trigger these doors if a double pole break glass is fitted. Or is that an added nicety? Quote
whistle Posted March 11, 2016 Posted March 11, 2016 The are classed as Emergency Door Release, nothing to do with fire. As you stated if the door needs to be used in an emergency what do they do. Haha they could always press a call point. Quote
Amps Posted March 11, 2016 Posted March 11, 2016 Depends on the security level required and the risk assessment. Quote
