netjordan Posted March 12, 2016 Author Posted March 12, 2016 He tried three batteries , I say it's the panel , had some where they give either continuous battery mis or mains fail , probably sold on eBay for that Raise case on eBay asap not as described I've raised the case on eBay - thanks everyone for their efforts with trying to diagnose this problem. Much appreciated. Quote
Nova-Security Posted March 12, 2016 Posted March 12, 2016 He tried three batteries , I say it's the panel , had some where they give either continuous battery mis or mains fail , probably sold on eBay for that Raise case on eBay asap not as described So he did in post 5 Dose every DIY (as its in the DIY section) have 3 7ahr batteries laying around ? Would have expected to see + Batt Miss Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
al-yeti Posted March 12, 2016 Posted March 12, 2016 Think he said three different batteries could mean anything Quote
netjordan Posted March 25, 2016 Author Posted March 25, 2016 Sorry to re-open old threads. I've since sent the panel back to the ebay seller and got a refund, then been out and got one from a reputable wholesalers but are still getting similar problems. All seemed to be good up until I connected power for 5 PIRs. However, now the symptoms are slightly different. I connect the battery - if I leave it at that all is good for a few minutes or so, after a few minutes the screen does turn off. Also if I try to exit engineer mode the display will turn off immediately. It seems to be when the panel is checking for the presence of a battery (as it would periodically and when exiting engineer mode) is when it causes it to turn off. Any ideas? Quote
andy82 Posted March 25, 2016 Posted March 25, 2016 Sorry to re-open old threads. I've since sent the panel back to the ebay seller and got a refund, then been out and got one from a reputable wholesalers but are still getting similar problems. All seemed to be good up until I connected power for 5 PIRs. However, now the symptoms are slightly different. I connect the battery - if I leave it at that all is good for a few minutes or so, after a few minutes the screen does turn off. Also if I try to exit engineer mode the display will turn off immediately. It seems to be when the panel is checking for the presence of a battery (as it would periodically and when exiting engineer mode) is when it causes it to turn off. Any ideas? Have you definitely connected the battery leads to the correct connection on the panel marked up as batt and not connected to the normal 12vdc output, failing that possibly you have a load of duff batteries, have you checked the charging voltage and current? Quote
norman Posted March 25, 2016 Posted March 25, 2016 Remove everything except the rkp and try again with the battery. Quote Nothing is foolproof to a sufficiently talented fool.
PeterJames Posted March 25, 2016 Posted March 25, 2016 use a 3.4 Ah battery you dont need 7Ah for 5 pirs a rkp and a bbox Quote
Andromeda Posted May 2, 2016 Posted May 2, 2016 On 24 March 2016 at 10:41 AM, norman said: On 11 March 2016 at 10:46 AM, norman said: Remove everything except the rkp and try again with the battery. Hi, I have the same problem with a g2-20 did you ever get to the bottom of the problem? I have bought another g2-20 card and I have the same problem and now the 12v doc Aux outputs are outputting continuously at 6v not enough to power up my rkp. Quote
al-yeti Posted May 2, 2016 Posted May 2, 2016 Op needs to send keypad back And to where did you get panel send it back provided your trying this with no loads etc Quote
Andromeda Posted May 2, 2016 Posted May 2, 2016 Panel was obtained from eBay and the rkp is the mk7 keyprox which I've had on my system for 7 years, the only loads on the panel were the keypad. Does is problem permanently damage the g2-20 board? Quote
