Dabsbhatti Posted March 15, 2016 Share Posted March 15, 2016 Dear All On a G2 44 - Is it possible to use a keypad proximity Keyfob only to set an alarm when leaving the house, but disable it so it cannot be used to unset the alarm on return? I'd like the unset to be done by entering the appropriate code at the keypad. I believe this can be done on the RF Keyfobs but not sure about the proximity ones. Thanks Nikki Quote Link to comment Share on other sites More sharing options...
norman Posted March 15, 2016 Share Posted March 15, 2016 Iirc cleaner attributes? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
james.wilson Posted March 15, 2016 Share Posted March 15, 2016 Does the g2 have all the access levels? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted March 15, 2016 Share Posted March 15, 2016 No didn't think so Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted March 16, 2016 Share Posted March 16, 2016 Does the g2 have all the access levels? Yes This allows the user type to be selected. There are 4 types available to choose from: 0 = Cleaner Can only set and unset the system 1 = User Can do all day-to-day operation but cannot override fault conditions 2 = Manager As per User but can override faults and reset alarms and tampers 3 = Master As per Manager but can add, remove and alter user codes. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Nova-Security Posted March 16, 2016 Share Posted March 16, 2016 and 8 = MAX Function This option allows users to be assigned a MAX function. 1 = Access Only This attribute allows a user to gain door access by use of a keytag or card in front of a MAX reader. 2 = Unset Only This attribute allows a user to unset the system by use of a keytag or card in front of a MAX reader. 3 = Set and Unset This attribute allows a user to set and unset the system by use of a keytag or card in front of a MAX reader. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
al-yeti Posted March 16, 2016 Share Posted March 16, 2016 Yes but not cleaner lol that's dimension Quote Link to comment Share on other sites More sharing options...
Dabsbhatti Posted March 16, 2016 Author Share Posted March 16, 2016 So that's a definitive "no" it can't be done I guess...not with a prox keyfob. Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted March 16, 2016 Share Posted March 16, 2016 Yes but not cleaner lol that's dimension No its a G2-44 we have loads like this, its in the manual pages 16 & 17 (had to check) So that's a definitive "no" it can't be done I guess...not with a prox keyfob. Yes it can be done, we have sites with G2-44 and set only option, may depend on the panel firmware though. Galaxy G 2 USER.pdf Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
al-yeti Posted March 16, 2016 Share Posted March 16, 2016 Ok I meant as in its not labeled same way so not as cleaner , unless you mean the 44 has it Quote Link to comment Share on other sites More sharing options...
