Joe Doherty Posted March 17, 2016 Posted March 17, 2016 Just a quick one option 65 if you plan on using autoset feature do you have to programme the times into submenu 1 timer A. Or can I just put the date & time direct into submenu 3 Autoset ? Many Thanks Quote
enasecurity Posted March 18, 2016 Posted March 18, 2016 Directly into sub menu 3 autoset (menu 65, option 3?) Quote
Joe Doherty Posted March 18, 2016 Author Posted March 18, 2016 yeah i put times in the autoset for tonight so hopefully should go to plan got set output set as a reflex so should send close hopefully. can than ceck at arc see if its worked ok Quote
Joe Doherty Posted March 18, 2016 Author Posted March 18, 2016 (edited) Does Group A1 have to be selected for it to set the system do you know ?. I have not set up groups on the system though but thought this might have to be put into the system for it to SET, Just assuming group A1 is everything on the Panel Circuits ? Edited March 18, 2016 by Joe Doherty Quote
enasecurity Posted March 19, 2016 Posted March 19, 2016 The groups will be whatever zones you've assigned to them, you don't have to have groups enabled for the system to set. Quote
Joe Doherty Posted March 19, 2016 Author Posted March 19, 2016 I programmed - S FRI ON 20.:00 - SAT OFF 08:00 Didn't have a Close signal to arc so assuming it hasn't set. Set output was reflexed so this should follow any set even without code will check log on monday Quote
enasecurity Posted March 20, 2016 Posted March 20, 2016 Was autoset turned on? Under autoset go to status (option 1) I think, and turn it on Quote
Joe Doherty Posted March 21, 2016 Author Posted March 21, 2016 Quick update i left before the other engineer and hes left it in engineer mode over the sabbath. Not handed system over yet, thats that mystery solved lol Quote
