Veritas Excel Transformer
Guest Deryck Tintagel
A friend has contacted me about his Veritas Excel. Apparently, the mains transformer is humming. I will not be able to look at it until next week but in the meantime does anyone else have experience of the transformer humming? I guess that this may be a replacement job but do Texecom supply just the transformer or is it a complete panel change? It will be under manufacturer's warranty.
Thanks
The Veritas is well renowned for the singing transformer.
Stud walls and them don't mix very well at all.
Try a SMALL drop of silicone inbetween transformer and housing.
This works well to muffle the sound.
Also, as was suggested above, isolate the panel from the wall with rubber washers or grommets.
Regards
Bellman
As Rich say's usually its the 4 tranny screws just work loose and you'll find the noise will all but stop on tightening.
A smack on the plates with hammer........! :wacko:
28364[/snapback]
Percussive maintenance Ian? :P:D
Best tool ive ever owned! :whistle:
28371[/snapback]
I know what you mean :whistle::lol:
Usually can be cured by tightening transformer screws, common problem.
Damn this topic, I'm sat in my living room and now I can hear the damn Veritas transformer in the Hallway!!!!!
Haven't got round to changing the panel since we moved in - i'd got used to the hum and now you lot have made me more aware of it than ever before!!!!
Thanks guys......
