Posted (edited)
Yes, a faceplate change is a million times better for you and the customer, EXCEPT when they have the hub or similar upstairs on an extension....
Although if they have 6 core running up there already I've never, ever had an issue with making the green pair, for example, DSL only from the unfiltered block on the plate.
I then change the affected socket for a double euro with one BT on the blue/orange pair and one RJ11 for the modem only on the green etc...
To be honest not had to do it for ages though with WW and 3G type comms.
Maybe an admin **** up?
HH5 can do ADSL and VDSL automatically
You maybe right, I suppose for most people they will see an improved in speed without coming to site.
I can't say I have seen Infinity without a MK3 etc round here.
Yes, I think it's intentional.
As you say most will just see an increase and be happy, even if it could be even better, they'll never know.
In dire cases they'll phone BT but if it saves 3 out of 4 home visits they're laughing.
Here we go, it's official, Infinity self install, even mentions 'if you DO already have a 'double socket', 'otherwise use plug in filters...'
http://bt.custhelp.com/app/answers/detail/a_id/47225/~/help-with-setting-up-bt-infinity-yourself
Edited by datadiffusion
The reasoning behind the Mk3 is to remove the interference from the ringer circuit that happens after the master socket.
May find that other FTTC providers have been switching over without getting Openreach in, so BT are doing the same.
I don't see why they don't supply you with a plug in master socket adapter plate filter as standard instead of the microfilters.
Come to think about it they make money selling them at the BT shop.
Eh? I thought it was to improve noise on the broadband what's it gotnto do with ringer circuit? I may have read you wrong
If the DSL is not filtered at the master socket it will be running around your house and picking up interference. Some of this comes from the ringer circuit.
Also you want to filter the DSL as close to the exchange as possible to get the fastest speed.
Another point to note is if you do use microfilters you may want to swap them out, the components in cheap ASDL filters may not be rated for the higher frequency of VDSL.
Ok I understand that , but I didn't think the mk3 was introduced for this reason, more for interferencebon broadband and as you said increase speed
Posted (edited)
The thing is the plug-in ones BT supply with the HH5 kits are the cheapest and nastiest I've ever seen!
A few years ago I was given a sample of a very nicely produced Fujitsu UK-made plug in filter, they must have been trying to impress BT for a bulk order, as I never saw them ever again or for sale etc... although if you google 'Fujitsu Microfilter' on ebay used ones can be found.
Interesting 'cut-down' pics page - http://www.adslnation.com/support/filters.php
Installed the MK3 and all working well, the HH5 was on the master but the MK3 does have an un-filtered output if its on an extension, these should be standard issue by BT, and yes the standard filters are nasty.
Posted (edited)
Yup the tiny 'hidden' unfiltred o/p is handy, amazingly some BT contractors don't even seem to know what it's for :(
Interestingly the 'Fujitsu' dongle (if it ever really was made by them) lives on here... http://www.pressac.com/_literature_3542/DS034_ADSL_Microfilter
