PSE Posted March 26, 2016 Posted March 26, 2016 Purely for testing purposes, Change the PIR mode from Hybrid to always awake Go through your scenario again, see if the results change This will prove your configuration setup are or hardware Remember to revert it back to Hybrid mode after Quote
Joe Doherty Posted March 26, 2016 Posted March 26, 2016 I thought guard access will cause full alarm condition if entry/exit timer has not.started. ie for a hallway pir. As the front door is not going.to be opened shouldnt it be programmed.as.timed.entry/exit zone Quote
Simlec Posted March 26, 2016 Posted March 26, 2016 I thought guard access will cause full alarm condition if entry/exit timer has not.started. ie for a hallway pir. As the front door is not going.to be opened shouldnt it be programmed.as.timed.entry/exit zone If you have a read of the manual it states a Guard Access zone will start the part set entry timer when system is part set. I personally use entry/exit 2 attribute and never had a problem. Quote
PSE Posted March 26, 2016 Posted March 26, 2016 Probably installed ten ish texecom alarms in last 3 years and mines the only one that doesn't seem to work properly, Are you really sure that its the equipment at fault, Like others, We use lots of Texecom. I don't experience this sort of issue I would recommend going through the manual again to get a clear understanding of the zone attributes and features As above, Guard access should start the entry timer when part set. Double check all other enabled options in the menu Quote
Joe Doherty Posted March 26, 2016 Posted March 26, 2016 If you have a read of the manual it states a Guard Access zone will start the part set entry timer when system is part set. I personally use entry/exit 2 attribute and never had a problem. Thanks.simlec will remember that for future only ever done premier elites on commercial jobs so never had a need to use part sets or out. If it was my house i would put a keypad in bedroom but thats personal prefernce Quote
