Posted (edited)
Quick question, premier panel,
I want to make an output flash on intruder.
I know it's possible I just can't figure it out what combination of type and attribute it is..
Edited by NotHeardofThat1
Strobe is just a steady output.
Some sort of custom one with a variable, resetting timer set to 0.5s?
Can you not just programme it as intruder and then change its attributes? To pulse?
Or is that galaxy I am thinking of and doesn't work here
I meant galaxy dimension can have attributes changed when set to intruder for example
Output programmed as Intruder with Random attribute and then minimum and maximum random times both set at 1second?  Errr... would that give a 1 second pulse, I dont have anything to test it?   Kinda depends on what flash rate your after too.
