ebay tsnetlcd (well depends how old the TS is, is the panel grey or white?)
or to change the lot replace it with a Texecom Premier 24/48. Closest panel you'll get in terms of connections/setup etc
Only TS700 keypads will work on a 700, they are getting rare.
You could change your code if you want a bit more life out of it.
Probably recommend a Prem if your looking to upgrade.
Easy, if you know what you are doing?
