Optima XM Alarm
Guest chucka
I have a Optima Alarm that was present when I bought the house severn years ago and I did have a engineer out about year ago to service the alarm .
Anyway I have a problem when I came home the wife said the alarm was activated thus I entered the code and all's was ok except when I try to enter the alarm code (In Day indicator mode) to exit the house it continually bleeps and Zone 4 Red LED is constantly on and this bleeps continually and the second tone bleep doesn't activates as before.
Thus on entering the alarm code Zone 4 LED is on .
Please advise on fixing this issue .
TIA
Chuck
What ever is on zone 4 (window,pir,door etc) is seen as open by the panel.Check the device (does the pir light up , has the door contact still got 2 halves??).
28347[/snapback]
Sorry if wrong forum Zone 4 is relating to ADE Optima XM House Alarm .
cheers
Chuck
cheers
Chuck
28348[/snapback]
Yep we know what an optima is chuck!
Zone 4 is a sensor of some kind or another, a door contact, a pir, whatever it is thats what you need to look at.
Chances are it is a door contact and maybe its wet with all the damp weather we have had. Just a guess but whatever it is you either need find out what zone 4 is or get an engineer to look at it for you.
28367[/snapback]
Hi Zone 4 is a pir light i.e I have inthe kitchen a Detector and the Red light acts with movement I assume that's the pir light device .
I have tried the omit it (code ,omit , 4, set) but I have to do this every time leave the house and hence zone 4 isn't activated .
If the zone 4 device is seen as open by the panel how do I cancel this or do I have to toggle with the device any suggestions as my contract is up and my house is up for sale .
TIA
TIA
28470[/snapback]
Hi Me again yes it's a PIR Motion dector that responds with the red light .
But how do I check it without tampering with it as it just points in the general direction of the Kitchen Zone 4 .
TIA
Try a walk test :-
PROG ,
CODE ,
0 , alarm tests
5 , walk test (lights + beep )
0 ,to cancel
RESET ,RESET.
If zone 4 is on all the time , then either the detector is goosed , or the wiring.
You could bypass it at the panel with a link to prove this, but that would leave the property unprotected.
Try a walk test :-
PROG ,
CODE ,
0 , alarm tests
0 ,to cancel
RESET ,RESET.
cheers again I will try the alarm test .
I hope it's not the wiring as it basically impossible to get too had the ceiling renovated thus wait and see after I run the test .
Thanks for your help I have a better understanding now as well as downloading the manual I never had .
Chuck
28478[/snapback]
28482[/snapback]
Hi Again I did the walk test and Zone 4 is still Open .
Thus I will just omit zone 4 for the ime being and when I have to sell get the man whom serviced it last time out .
cheers for the help at least I got a better understanding of the problem and how my alarm system works .
