False Alarms on Optima XL6
probably the battery, but running it so low can damage the panel.
just run without the battery connected and does it still false alarm? I suspect not.
Then replace the battery and see what happens, if it messes up again then replace the panel.
Link to comment
Share on other sites
  • 1 month later...
Hi,
I have replaced the battery but after I try to use several times in the night and it give 2 false alarm. After I stop the sound by tap pin number and the day light is off. I try to reset the system afterwards but never get it working again with day light off and can not hear the bip when i press the number key. Can someone give me a clue what is wrong?
thanks
Link to comment
From that description it could be many things my guess would be that the charging circuit did get damaged from the earlier problem, I would lay money that your new battery is not charging. check the voltage
Link to comment
