James Schultz Posted April 19, 2016 Posted April 19, 2016 (edited) Dear Security Installer Forum Members, For my installer team , I need a request from you. We install Dimension series in a building. By the way we could not configure the exit module while we configured entry. When I read on the manual it tells about activating exit on the menu, but how? I appreciate for your replies. Dimension Installer Manual , 69.3 = DCM This option is used to program the Galaxy Door Control Module (DCM) access control readers. The DCM can be fully integrated into the system, communicating on the AB lines and fully utilising the facilities of the Galaxy control panel. Each DCM can control up to two readers. The exit reader can be replaced with a request to exit button. When enabled, the options that are eligible for DCM programming are made available throughout the menu, otherwise they do not appear, or appear as Option not Available. Edited April 19, 2016 by James Schultz Quote
james.wilson Posted April 19, 2016 Posted April 19, 2016 I dont understand what your asking? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
James Schultz Posted April 19, 2016 Author Posted April 19, 2016 Dear James , I have DCM module. C080 is the name of the product. You can find the product in this link http://www.security.honeywell.com/uk/products/intruder/control-panels/accessories/accesscontrol/466174.html I configured the card readers, Card readers are working now, but I have an exit button. I do not know how to configure the programming of Exit button to the DCM module. I made wiring of exit button to the DCM Module. Is it clear now? Thanks for your quick reply. Quote
james.wilson Posted April 19, 2016 Posted April 19, 2016 You wire it into the dcm. Can you upload a picture of the pcb? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
James Schultz Posted April 20, 2016 Author Posted April 20, 2016 Hi James , Here you can see the pictures. Do you see anything wrong? Quote
Nova-Security Posted April 20, 2016 Posted April 20, 2016 Thought a DCM was looking for o/c going to 1K on the RTE not 2K going to 1K Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
James Schultz Posted April 20, 2016 Author Posted April 20, 2016 Can you explain more ? Should I connect 1K to module? If possible can you show on picture? Thank you very much Quote
Nova-Security Posted April 20, 2016 Posted April 20, 2016 have you made sure that the door contact or how you are monitoring the lock is showing closed (1k), DCM wont open the door if it already showing open. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
James Schultz Posted April 21, 2016 Author Posted April 21, 2016 Thanks for your answer. We wired as you said but it did not work. After wiring is it needed to program over keypad ? Quote
jammin31 Posted April 21, 2016 Posted April 21, 2016 It sounds like you would benefit from someone who knows this setup popping over to assist you, if your an installer have you tried tech support ? Quote
