Hello, I was wondering if anyone would be able to give some advice on how to wire up this alarm, e.g which terminals would be for the tamper and which would be zones, it isn't easy, but someone out there may know how to connect it up, it was made by Revdun Electronics Ltd and it is very high quality Here are some pictures... Thanks in advance
I have a bit of a collection of old alarms, this is by far the oldest, and I just needed help wiring it up, it isn't like an Accenta or anything else, do you have any idea how to connect it up?
Don't know which is more tragic Gabs posting or me replying....
Can't recall touching a "DS100"
the pic shows pots for for entry & exit times,
There appears to be 3 zones
"F" Full?
"P" Part?
"E" Entry?
Then PA Zone
Buzzer Outputs
Then Bell output
I'd guess the lines show circuits?
Outer terminal & Inner terminals for the 3 zones
PA is terminal next to one another
Bell tamper return outer terminals
Link everything out hold the case tamper in & turn the key, if you (well me) has cracked it should start to set....
Thank you, I will try that, I was worried in case I shorted something out, there are no fuses inside the panel, so that's not good, I will try it, and hopefully it'll work, anyone herd of 'Revdun Electronics' before?
there a chance whoever made it is dead...
Name of Company REVDUN ELECTRONICS LIMITED Nature of Business MANUFACTURE of BURGLAR ALARM CONTROL PANELS Address of Registered Office 43 Temple Row, Birmingham B2 5JT Liquidator's Name and Address Richard A Stone and Adrian R Stanway, Cork Gully, 43 Temple Row, Birmingham B2 5JT Date of Appointment 23rd August 1985 By whom Appointed Creditors (864)
Okay, well, I hopefully will get it working, it has an SAB I will also try to connect up, it looks fairly easy to connect, so which terminal would be the 13v output
