smashwings Posted April 25, 2016 Posted April 25, 2016 Hello, would like to set a Texecom Premier 816 with a wired PIR sensor in entry hall (no door contact) , and would like to know if this sensor can be active while arming the alarm because the PIR sees me in the hall. (In an old DSC PC1500 I had, door sensor should be closed) Entry/exit zone in installation manual says "The zone can be activated during the exit mode without causing a ‘Fault’ " ,I don't know if zone can be activated only after arming or if it also refers that it can be "active" while arming. Thank you Quote
sixwheeledbeast Posted April 25, 2016 Posted April 25, 2016 Yes, but the the system with have to be set to Timed Arming Quote
smashwings Posted April 25, 2016 Author Posted April 25, 2016 Thanks, but cannot see how timed arming is activated in the installation manual, can only find some references in outputs section Quote
petercts Posted April 25, 2016 Posted April 25, 2016 hi this is changed under arming modes in area programe section Quote
secureiam Posted April 25, 2016 Posted April 25, 2016 (edited) The 816 doesn't have the same programming structure as the Premier/Elite 12 to 640's have to be honest never had much to do with them so I would be looking at the manual and trying to work it out. Wintex does have the options marked with the code used at the keypad to access them. Edited April 25, 2016 by secureiam Quote
smashwings Posted April 25, 2016 Author Posted April 25, 2016 1 hour ago, secureiam said: The 816 doesn't have the same programming structure as the Premier/Elite 12 to 640's have to be honest never had much to do with them so I would be looking at the manual and trying to work it out. Wintex does have the options marked with the code used at the keypad to access them. Have looked at the Elite Manual and it includes the Timed Exit, but not the Premier one, so it's not available for premier panels? (don't have the panel to test, only manuals) Quote
J&D Security Posted April 26, 2016 Posted April 26, 2016 I think there is a setting somewhere to allow arming whilst a zone is violated (active), the zone needs to be secure by the time the system is armed otherwise you'll get a arming fault. Quote janddsecurity@live.co.uk
smashwings Posted April 26, 2016 Author Posted April 26, 2016 J&D , in Zone Attributes 2 there is "Enable Force Arming" as an attribute to a zone "The user can arm the system/partition with the zone violated." I don't know if this attribute can be assigned to the "Delay 1" zone (entry), I suppose yes, Also I asked to Texecom mail and they answered that "the international panel it is automatically a timed set" "As long as the zone is not active once the timer has expired then it will set". Anyway, if Timed exit works from default or Force arming zone can be set as an attribute, there will be chances for the PIR to work as entry sensor Quote
J&D Security Posted April 26, 2016 Posted April 26, 2016 Looks like you don't need to do anything is what Texecom are saying. Just try it and see Quote janddsecurity@live.co.uk
secureiam Posted April 26, 2016 Posted April 26, 2016 You need the 412/816/832 manual if you have the 816 panel, the premier 24,48 etc and the Elite manuals would be no good to you. the 412/816 and 832 were mainly international panels, although UK variants exist (UK bell module). how long is the exit delay timer set to? Quote
