JCJ Posted May 4, 2016 Share Posted May 4, 2016 Hi guys, can anyone help me out with the following. I have an accenta compact. My problems first started with zone 1 which is a PIR. The keypad was showing the zone 1 LED and the internal sounder was producing a rapid tone. This was preventing the system being armed. I joined through the the alarm and tamper pair in the PIR and the above stopped and I could arm the system. So I replaced this PIR. The system then allowed me to arm. However, the following day external siren was activated but There was no indication as to what caused the alarm. I then had trouble silencing the external sounder. The system would even allow me to arm it while the sounder was still sounding. I undid the bel box to find a couple of fairly loose connections. I tightened these but now the bell box does not trigger. But. If I remove the fuse in the panel then the sounder operates via its batteries. Can an anyone point me in the right direction so that I can get things back up and running? Thanks in advance!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40089-intruder-fault-help/ Share on other sites More sharing options...
james.wilson Posted May 4, 2016 Share Posted May 4, 2016 Faulty bell, bell tamper or loose tamper in the bell securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40089-intruder-fault-help/#findComment-445872 Share on other sites More sharing options...
JCJ Posted May 4, 2016 Author Share Posted May 4, 2016 Thanks for the reply. The tamper connection was loose when I opened up the bell box. All connections are now tight. what is the best way to test to clarify to root cause? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40089-intruder-fault-help/#findComment-445874 Share on other sites More sharing options...
