Rob Kirk Posted May 6, 2016 Posted May 6, 2016 (edited) https://www.amazon.co.uk/Decking-Kitchen-Plinth-Lighting-Small/dp/B012OTNWPY/ref=sr_1_18?ie=UTF8&qid=1462522859&sr=8-18&keywords=small+decking+light Want to wire these in my new house every other stair, want to have a fused spur in the hallway connected from the switched live and neutral of the hallway lights. Thing is the power supply on that is plug type, just want to know what power supply i should buy so i can connect it to a fuse spur. I was never any good at working out what type of power supply is needed so pls go easy on me A link to the correct one would be great, it has to be non plug type (or one i can cut a mains plug off and wire into a fuse spur, not the sealed plug type) Edited May 6, 2016 by Rob Kirk Quote
al-yeti Posted May 6, 2016 Posted May 6, 2016 Have you bought the kit yet? Otherwise it doesn't seem to mention what it is, some are 24v some are 12v , buy the kit then work out what supply you need as it will be on the supplied power pack or use a meter Quote
petercts Posted May 6, 2016 Posted May 6, 2016 hi if 12 volt dc as per picture old cctv psu or new led driver from tool station - screwfix Quote
norman Posted May 6, 2016 Posted May 6, 2016 Why not combine with a covert PIR module in the top and bottom step to switch on for a pre set time? Quote Nothing is foolproof to a sufficiently talented fool.
Rob Kirk Posted May 6, 2016 Author Posted May 6, 2016 10 hours ago, norman said: Why not combine with a covert PIR module in the top and bottom step to switch on for a pre set time? Great idea thanks Norman! Quote
PeterJames Posted May 6, 2016 Posted May 6, 2016 Make sure you set the timer just long enough for the mother in law to get only half way up 2 Quote
secureiam Posted May 7, 2016 Posted May 7, 2016 12 hours ago, PeterJames said: Make sure you set the timer just long enough for the mother in law to get only half way up classic but thought they could see in pitch black over 100m 1 Quote
