Guest RICHL Posted October 22, 2004 Posted October 22, 2004 on some versions of the contour keypad the number 1-4 is read the other way from others, maybe the link is on pin 4?
Guest Guest Posted October 22, 2004 Posted October 22, 2004 Have you corectly placed the EOL jumper on the keypad..?Oh and BETTER picture Georg 28557[/snapback] Jumper for US is removed allowing high security mode for ACE. Jumper A4 is in place to set keypad 1. Jumper NVM is removed so as not to clear memory. There are no pins on the pcb where the legend says EOL? Thanks for everyones continued suggestions. David
Guest Posted October 22, 2004 Posted October 22, 2004 what about KP jumpers (thou i am not sure if there is any..)?
Service Engineer Posted October 22, 2004 Posted October 22, 2004 Isn`t A4 for keypad 4..? A4 RKP Address 4 Only fitted to Gardtec 800 Series RKPs A3 RKP Address 3 Only fitted to Gardtec 800 Series RKPs A2 RKP Address 2 Only fitted to Gardtec 800 Series RKPs A1 RKP Address 1 Only fitted to Gardtec 800 Series RKPs ........................................................ Dave Partridge (Romec Service Engineer)
Guest Guest Posted October 23, 2004 Posted October 23, 2004 Many thanks to everyone who offered suggestions, most appreciated. Finally resolved problem by changing keypad jumper to A4 and voila, everything now working fine. Once again, many thanks to everyone. , David
