MrHappy Posted May 11, 2016 Posted May 11, 2016 1.6hdi, been wiped but did'nt look much worse before... Elm's a couple of quid & limited in its use, I've also a knock off lexia which I've not quite managed to get going 1 Quote Mr Veritas God
al-yeti Posted May 11, 2016 Posted May 11, 2016 You get the leads with the lexia or just software ? It can be funny Wdt where you get 1200bar from? Quote
norman Posted May 11, 2016 Posted May 11, 2016 Injector Quote Nothing is foolproof to a sufficiently talented fool.
MrHappy Posted May 11, 2016 Posted May 11, 2016 44 minutes ago, norman said: Injector maybe, its getting cleaned up with brake cleaner & sold Quote Mr Veritas God
al-yeti Posted May 11, 2016 Posted May 11, 2016 1.6hdi are underpowered and poor engines , although the 2.0 do suffer from leaking pumps 1 Quote
MrHappy Posted May 11, 2016 Posted May 11, 2016 1 minute ago, al-yeti said: 1.6hdi are underpowered and poor engines , its only a van.... Quote Mr Veritas God
norman Posted May 11, 2016 Posted May 11, 2016 5 hours ago, MrHappy said: maybe, its getting cleaned up with brake cleaner & sold I was answering als dumb question. Quote Nothing is foolproof to a sufficiently talented fool.
WDT Posted May 11, 2016 Posted May 11, 2016 9 hours ago, al-yeti said: You get the leads with the lexia or just software ? It can be funny Wdt where you get 1200bar from? Ha Ha I mis-typed and you spotted it, it's full pressure is more like 1600 bar Quote
WDT Posted May 11, 2016 Posted May 11, 2016 11 hours ago, MrHappy said: Just a thought next time you are under there just check the allen bolts that hold the injector down are tight, Most the time when i see leaks on the main feed to the injectors it's very wet (Like Dripping wet ) Quote
