Hello everyone,
I currently have a problem when people are using the gym facilities without paying their fees.
The main issue we've got is that the gym have grown in size which has created a blind spot to the reception area thus allowing people to sneak in.
Its only one door that requires access control.
I've seen DIY kits that can be bought on eBay but they are standalone systems that would need to be programmed at the door.
Also there is four levels of membership
1, daily
2, weekly
3, Monthly
4, Annually
Does anyone have any advice?
Thanks
NWR
1 hour ago, NWR said:
Do you have any links to the systems please?
Single door kit is cira £350+vat which is the cheaper end for access control,
You'll then need a lock a PC, a token for every user & a what ever time it takes to get it all working,
good luck
2 hours ago, norman said:
You lost me at Gym membership
Do you not remember, its that place that has a new machine you like, you know the one that vends mars bars, snickers, kitkats.
  • Upvote 1
2 hours ago, NWR said:
Hello everyone,
1, daily
2, weekly
3, Monthly
4, Annually
Thanks
NWR
If your looking on ebay already you cant afford the kit I would advise, as others have said PC based with anti pass back expect to pay circa £1k per door installed
Axis 1000 unit would be good for online 3rd party integration with membership etc... but no doubt it's all been done before
and most gym memberhship software supports a certain manf's gear?
For a gym, I wouldn't be honest be too bothered about anti passback unless a completely unattended situation.
Bit unfair.
