Vignesh Posted May 22, 2016 Posted May 22, 2016 Hello Friends I am vignesh and am working in fire alarm Maintenance dept. I have some doubts to clarify with you guys. I am working in a facility there they using honeywell Addressable control panel, smoke detector and heat detectors. there are some detectors not working, the same model detectors not available in the market. please give me a solution regarding this issue other than complete change the system. If we use Gent brand same capacity detector means the system accept the detector and working? Quote
Lwillis Posted May 22, 2016 Posted May 22, 2016 Surely if your working in a fire alarm maint dept you should have the knowledge and experience to not be asking this question. which Honeywell panel is it? Quote
Pete001 Posted October 18, 2016 Posted October 18, 2016 Honeywell has a unique protocol and as far as i,m aware only available from honeywell. Notifier detectors will not work on this system Quote
firemonkey Posted March 3, 2017 Posted March 3, 2017 Honeywell is an odd one.. Some use system sensor protocol but it's impossible to say as your post lacks the basic information needed to give a proper answer Quote
