jjohn Posted June 1, 2016 Posted June 1, 2016 greetings, i have to quote to replace a menvier control panel which was once on redcare but bells only now. the keypad appears to be exactly the same as a mevier m800 series panel, there is what looks like one of menviers node expanders next to the panel and the zone list is numbered as zones 0001 to 0006 which i assume is wired off the panel and zones 2011 to 2018 which i assume are zones wired from the expander next to the panel. i have not opened the panel. can i also assume that this is not an id biscuit panel? it would be handy to assertain this before i quote to fit with a standard double pole eol panel. i have attached a library picture of keypad and node. thanks. Quote
jjohn Posted June 5, 2016 Author Posted June 5, 2016 well this is why im here asking these questions and showing photos of the equipment! Quote
MrHappy Posted June 5, 2016 Posted June 5, 2016 40 minutes ago, jjohn said: and showing photos of the equipment! I'd assume the plastic box was same for all the supported nodes ? What controls do you intend to put in its place ? Quote Mr Veritas God
petercts Posted June 5, 2016 Posted June 5, 2016 hi the problem is menvier used the node box for ever thing for many years from a six zone expander to radio node to x node or m node and if the panel box is full size they used that for years to Quote
