Hi folks
Am doing a self install on a new build house and need some help on a few things if you don't mind.
I have the following:
Accenta mini gen 4
AD-01 Auto dialler
AG6 External sounder & strobe.
1) How do I wire the Auto dialler into the gen 4?   Terminals on Auto dialler are: Tamp (x2), TR2, TR1, 0v & 12v+.
Think these wires should go to Panel J3 on the gen 4 and the terminals are +13v, 0v, Fire, PA,INT, SET & ABORT?
2) How do I wire the External strobe into the gen 4?  Terminals on strobe are:  ST- (strobe trigger), R- (Tamper return), SW- (Sounder trigger), V+ (positive supply & V (negative supply.
Think these wires should go to Panel J6 on the gen 4 and the terminals are : + strobe, - strobe, T (scb), A (scb), D (bell), B (bell) & set.
Thanks in advance
Peter
Posted (edited)
For the dialler Connect the
+13v To +
- 0v to -
B to tr1 (b Aslong as it's the negative bell trigger)
This is simplest way
D BELL is the plus + hold off so don't get confused by that or AMP lol
Edited by al-yeti
  • Upvote 1
Posted (edited)
For the bell
Generally ( I having a snooze)
R Tamper return to T
Dbell to v +
0v to v -
-bell to - sw
- strobe to -
Don't use +strobe if it's there
Edited by al-yeti
  • Upvote 1
