enasecurity Posted June 8, 2016 Posted June 8, 2016 Evening all, I've gone to go out and arm my texecom system today, however when pressing 'area' to quick arm, the keypad produces a long beep and says 'keypad locked!' I have tried pressing yes and no down together to unlock the keypad, but it doesn't seem to work. Wintex works fine though. Will it be a case of power cycling the panel or am I overlooking something? Quote
sixwheeledbeast Posted June 8, 2016 Posted June 8, 2016 Keypad lock is built in to the keypad AFAIK. Maybe a button is stuck stopping you from unlocking it? Quote
secureiam Posted June 9, 2016 Posted June 9, 2016 (edited) Yes and No is the way to go Edited June 9, 2016 by secureiam Quote
sixwheeledbeast Posted June 9, 2016 Posted June 9, 2016 Did I miss something? The OP said Yes and No. Quote
PSE Posted June 9, 2016 Posted June 9, 2016 1 hour ago, sixwheeledbeast said: Did I miss something? The OP said Yes and No. Doesnt always work correctly by pressing at the exact same time, I always demonstrate to customers by keeping YES pressed in, before pressing NO 1 Quote
MrHappy Posted June 9, 2016 Posted June 9, 2016 1 hour ago, PSE said: Doesnt always work correctly by pressing at the exact same time, I always demonstrate to customers by keeping YES pressed in, before pressing NO the early ones work, later ones need your trick Quote Mr Veritas God
enasecurity Posted June 10, 2016 Author Posted June 10, 2016 I was quite close to using a brick to unlock it! But thanks PSE, the trick worked! Quote
secureiam Posted June 10, 2016 Posted June 10, 2016 (edited) always done yes and no, rather than at the same time hold down yes and no. only other lock is a code lock which should reset its self after x hours, but don't get many of them. Brick is always useful in your tool kit....lol Edited June 10, 2016 by secureiam Quote
