Same footprint as the Nano, now supporting:-
Single path IP, 3G
Dual path IP/3G, 3G/3G and IP- 3G/3G
IP connectivity is supported in either cabled or wifi format.
Panel connectivity via Serial data bus or Dial Capture including 9 hardwire inputs and 2 relay control outputs.
The first wire free dual path signalling solution.
WebWayOne - Stand F1250
Jim Carter
WebWayOne Ltd
www.webwayone.co.uk
