sharkey Posted July 5, 2016 Posted July 5, 2016 Hi all My mother does not want wires inside house for a CCTV system she can view downstairs so I was looking at running in via loft and using dual port powerline adaptors to connect the two IP cameras into, then I would connect the other powerline into the router downstairs and buy her a tablet and run viewing off the App.dual port. Recording would be via onboard camera storage Would this setup work and what Powerline adapters, cameras and tablet would anyone recommend? Thanks for looking Quote
cybergibbons Posted July 5, 2016 Posted July 5, 2016 Can't see any reason why it wouldn't work. Just be aware that the adapters get warm, and don't like being covered. I'd provide for means of power cycling without climbing into the loft, if possible. Quote I have a blog, some of which is about alarm security and reverse engineering:http://cybergibbons.com/
petercts Posted July 5, 2016 Posted July 5, 2016 hi have used powerline adapter to network dvr back from out buildings and down from the loft on many jobs use tp link 300 or 500 mps models find they work 99.9 % of the time without a problem, if they lock up you need to reset the mains .the cheap ones off ebay rated at 100mps fail after a few months, also the one that you can still put a 13 amp plug in also cause problems i have found they all require a good earth and work well over 100m if on the same fuse board also used in offices with covert camera installs Quote
PeterJames Posted July 5, 2016 Posted July 5, 2016 Until recently I was using them for all my outbuildings, they were fine. I have since wired to the main outbuilding because I wanted to put the NVR in it along with some other stuff and I would have had restricted bandwidth connecting remotely to the NVR Quote
