Posted (edited)
I have a optima xm6, it is keeping ringing after a power cut.
there is only power led showing, none of mode or zone led is showing
I have tried code ####, not work
I have tried reset to factory settings in a bid to cure problem but still no change.
I have tried to enter engineer mode, it does not work
I have disconnected the battery-power off-poweron-code ####, still not work.
can anyone advise me how to solve this problem without call out an engineer?
Edited by sixwheeledbeast
No codes please
1 hour ago, james.wilson said:
you need to call your service provider they will send someone as it shouldn't have an issue with a small power cut.
any number can reach optima? the alarm is there already when I moved in, not sure who is installer
Optima is the model, the  manufacturer is no longer. Is there no phone number on the external box? It could be a diy system so you may have to get the yellow pages out and try and find someone willing to come out to it.
