no my point was/is
Quote
If I do the same with the wired PIR, I get event logs of "Alarm - Zone 003 Guard Alarm" followed by "Confirmed intruder" and "Confirmed alarm" then "Bell active".
why is zone 003 causing confirmed intruder
unless as above its set to only ring on confirm and you are actually triggering 2 devices?
Just browsing the texecom manual
Under Area settings whats the difference between 00 - Alarm and 01 - Guard alarm
Okay from the comments posted (thanks by the way!) I've changed the PIR's into "AUTO" mode instead of Hybrid.
I'm thinking the comments about a single device/zone not triggering a confirmed alarm is the problem - my expectation is it would set bells active.
Are you suggesting that if somebody breaks into a single room (i.e. lounge) the PIR would detect this, but not set bells active because only a single sensor has detected it ?  Bit pointless if thats the case!
I've done another capture in WinTex of the events
The events below show the alarm arming, and then me leaving the system for a couple of minutes to settle.  I then activate the zone 009 PIR (Toilet!) - the action is registered by the alarm (active) but no bells.
After a minute, I then activate zone 011 and the alarm activates + bells + confirmed alarm.
0478    5:54:22 PM    12/07/2016    Not Reported    A . . .     Exit Started Net 1 - Rkp 1
0479    5:54:37 PM    12/07/2016    Close    A . . .     Area(s) Quick Armed
0480    5:56:26 PM    12/07/2016    Alarm    A . . .     Zone 009 Guard Alarm - Toilet PIR
0481    5:56:27 PM    12/07/2016    Not Reported    A . . .     Alarm Active
0482    5:56:48 PM    12/07/2016    Restore    A . . .     Zone 009 Guard Restore - Toilet PIR
0483    5:57:27 PM    12/07/2016    Alarm    A . . .     Zone 011 Guard Alarm - Living Rm PIR
0484    5:57:28 PM    12/07/2016    Priority Alarm    A . . .     Confirmed Intruder
0485    5:57:29 PM    12/07/2016    Alarm    A . . .     Confirmed Alarm
0486    5:57:29 PM    12/07/2016    Not Reported    A . . .     Bell Active
0487    5:57:32 PM    12/07/2016    Restore    A . . .     Zone 011 Guard Restore - Living Rm PIR
0488    5:57:33 PM    12/07/2016    Not Reported    A B C D     System Access by User 03 - Family
0489    5:57:33 PM    12/07/2016    Open    A . . .     Area(s) DISARMED
0490    5:57:33 PM    12/07/2016    Open    A . . .     Alarm Abort
This second activation shows zone 009 being activated again, but no confirmed alarm.
0491    5:57:46 PM    12/07/2016    Not Reported    A . . .     Exit Started Net 1 - Rkp 1
0492    5:58:01 PM    12/07/2016    Close    A . . .     Area(s) Quick Armed
0493    6:00:14 PM    12/07/2016    Alarm    A . . .     Zone 009 Guard Alarm - Toilet PIR
0494    6:00:15 PM    12/07/2016    Not Reported    A . . .     Alarm Active
0495    6:00:19 PM    12/07/2016    Restore    A . . .     Zone 009 Guard Restore - Toilet PIR
0496    6:00:54 PM    12/07/2016    Not Reported    A B C D     System Access by User 03 - Family
0497    6:01:03 PM    12/07/2016    Not Reported    A B C D     System Access by User 03 - Family
0498    6:01:07 PM    12/07/2016    Open    A . . .     Area(s) DISARMED
0499    6:01:07 PM    12/07/2016    Open    A . . .     Alarm Abort
Assuming this is the correct way the system is supposed to work - what are my best options for securing a room - multiple PIRs ?
hi
if the panel is programed to bells and sounder on confirmed this is used on commercial or large domestic systems  mainly on a police response system   confirmed alarms  need two detectors to activate  in one area to generate an audible alarm
an example is one detector in a shop by the front door and a 360 disc  in the same area  if one  activates the alarm send an unconfirmed signal  if both see movement then the bells ring and it sends a confirmed alarm
if you have only one detector in a room and you want an audible alarm  you need to change the option in wintex  under system config to bell 1st alarm  and sounder 1st alram
hope this  helps
peter
6 minutes ago, petercts said:
hi
hope this  helps
peter
Stuart,
As peter said the setting can be changed
janddsecurity@live.co.uk
Thank you for the help.  I've not tested this yet, but it makes sense.
To summarise the issues resolved:
1. Ensure PIRs are in AUTO mode
2. Untick option 26 and 27 for "bells on confirmed alarm" (switched off)
hi
 is it still set to grade 3! if so you only need grade 2 this is a great system but is not intended as a easy diy fit  it is aimed at high security  and a police response.
