Nova-Security Posted July 15, 2016 Share Posted July 15, 2016 10 hours ago, james.wilson said: Samsung are rumoured to have a home automation plan, best not click remove lounge settings by mistake... Where samsung smart Tvs spying on you ? Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
mrbloop Posted July 15, 2016 Author Share Posted July 15, 2016 19 hours ago, norman said: Those lenses look like they will give a very wide spread, probably take Mr Blobby to trip them. probably doesn't help then that I'm rather skinny! Going off that thought I decided to try reducing the amount of infrared light hitting the receiver sensors. Using some copper tape I crudely taped off the lenses, and low and behold it's now a lot more sensitive! Actually working ok now, not perfect but from the little testing I've done it's much better. I don't have time to test much further today but I'm certainly much happier with them now. In the manual it states that for this model the guarding distance is 100m and beam spread is 4.5m (I assume that is the spread at 100m?). Quote Link to comment Share on other sites More sharing options...
mrbloop Posted July 15, 2016 Author Share Posted July 15, 2016 (edited) 17 hours ago, datadiffusion said: Isn't this Chinese stuff 433 mainly as well though? Yes it is 433MHz. Other things I've discovered… breaking the beams closer to the infrared transmitter side is a lot more accurate at triggering (it's perfect at distances of approx. 2m or less), I suppose this is because the beams are not very spread at this distance. The silver screw in the pic above can be used to fine tune horizontal adjustment (in addition to swiveling the lens housing by hand) Edited July 15, 2016 by mrbloop Quote Link to comment Share on other sites More sharing options...
J&D Security Posted July 15, 2016 Share Posted July 15, 2016 How are you checking the alignment. The beams I've used before either had led indicators or you had to use a volt meter to measure an output and get the output into a certain range, different led's or voltages meant different alignment strength. There must be a method to check with this type of beam, perhaps they aren't aligned correctly. Quote janddsecurity@live.co.uk Link to comment Share on other sites More sharing options...
james.wilson Posted July 15, 2016 Share Posted July 15, 2016 id assume with poor alignment they would be more sensitive Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Stevenwei Posted August 17, 2016 Share Posted August 17, 2016 On 2016/7/15 at 6:01 PM, mrbloop said: probably doesn't help then that I'm rather skinny! Going off that thought I decided to try reducing the amount of infrared light hitting the receiver sensors. Using some copper tape I crudely taped off the lenses, and low and behold it's now a lot more sensitive! Actually working ok now, not perfect but from the little testing I've done it's much better. I don't have time to test much further today but I'm certainly much happier with them now. In the manual it states that for this model the guarding distance is 100m and beam spread is 4.5m (I assume that is the spread at 100m?). a 100m level infrared beam sensor is not recommended to be installed in such a short distance, emitting infrared from transmitter is pretty strong that some of them could spread and reflect via obstacles nearby to the receiver. Quote Link to comment Share on other sites More sharing options...
