OtisStuart Posted July 14, 2016 Posted July 14, 2016 Hi all, I'm a newbie here so forgive my ignorance if this is an easy one. I have a galaxy panel and the customer would like me to fire a small relay to power some led lights when a certain zone is activated with a double knock attribute. While I'm reasonably happy with firing the output I'm at a bit of a loss as to how I set the zone up for double knock operation. I work mainly/exclusively on Risco and Gardtec equip and the terminology within the honeywell programming manual doesn't seem as straight forward with regards to the double knock feature attributes for the zones. Any help would be appreciated. Thanks Quote
9651 Posted July 21, 2016 Posted July 21, 2016 G2 has no double knock, must be the only panel out there that doesn't. Quote
OtisStuart Posted July 21, 2016 Author Posted July 21, 2016 Thanks 9651, I've already been in touch with Honeywell and been told that exact thing. So hey ho it'll just have to be standard operation or nothing. Thanks anyway Quote
james.wilson Posted July 21, 2016 Posted July 21, 2016 On 21/07/2016 at 21:06, 9651 said: G2 has no double knock, must be the only panel out there that doesn't. Expand good don't know why any would, it breaks reg, hides issues and should ever be needed Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted July 24, 2016 Posted July 24, 2016 On 21/07/2016 at 21:40, james.wilson said: good don't know why any would, it breaks reg, hides issues and should ever be needed Expand I don't agree any panel can be programmed incorrectly or non-conforming. IMO equipment should be as flexible as possible. Installers should know the regs and more importantly the companies should teach the regs to those installers. Quote
james.wilson Posted July 24, 2016 Posted July 24, 2016 I agree re flexability bit have you ever used it? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted July 25, 2016 Posted July 25, 2016 Yep but not for any customers, I would remove and docket any DK attributes found on a maintenance. Found a one way radio garage PIR on double knock a few weeks back, wouldn't operate correctly as PIR would sleep after one knock. Seen contacts on DK too, again all down to engineers being properly trained. Quote
norman Posted July 25, 2016 Posted July 25, 2016 On 25/07/2016 at 11:25, sixwheeledbeast said: all down to engineers being properly trained. Expand and giving a toss. 1 Quote Nothing is foolproof to a sufficiently talented fool.
Amps Posted July 29, 2019 Posted July 29, 2019 On 21/07/2016 at 21:40, james.wilson said: good don't know why any would, it breaks reg, hides issues and should ever be needed Expand Which reg? Quote
Nova-Security Posted July 29, 2019 Posted July 29, 2019 bs4737 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
