Hi All,
Further to a previous post I managed to solve my alarm-related problems and reconfigure the system... however the Scantronics 9427 remote keypad keeps showing a green flashing Power LED. Rather baffling since the main 9448+ control panel shows solid green and everything is working perfectly??
However, when I put the alarm in Engineer/Programming Mode, then the Power LED does go solid green.
Any ideas what might cause this behaviour?
Many thanks in advance for your feedback.
It's telling you to install a 9651...
The 9448 really is very old hat. With the 9651 you'll get a text LCD display, be able to use fobs, but it's just as easy to use.
Also the terminology and tones are the same so a nice bit of familiarity... All for the price of McDonalds for four...
  • Upvote 1
Hi 'Data'
OK then... that sounds like a plan indeed. An LCD screen would definitely help and fobs are definitely a nice to have feature :-)
And I guess I would be able to keep the existing cabling?
Many thanks
Posted (edited)
Cool... that would be a nice little project and would get my hard-wired alarm in the 21st Century... thanks for the tip :-)
(about £** is really not expensive indeed)
Edited by datadiffusion
