bazzacool Posted August 5, 2016 Posted August 5, 2016 (edited) Hi I have a Scantronic 9800 and just updated to 9800+ after main board failure. All ok except the internal sounder is deafening on alarm set. The volume control does not alter it and there does not seem to be a setting that will allow just key pads to bleep only. Is there a setting to turn off the internal sounder on a set but activate on an alarm? I cannot see a setting in the manual that would cover this. If there is not a setting to do this can I run the sounder off the strobe circuit so it only activates on alarm? Thanks Adrian ] Edited August 5, 2016 by bazzacool Quote
MrHappy Posted August 5, 2016 Posted August 5, 2016 On 05/08/2016 at 01:11, bazzacool said: just updated to 9800+ Expand wow, welcome to the yr 2000..... or there abouts Quote Mr Veritas God
Jim Randle Posted August 5, 2016 Posted August 5, 2016 Hi Adrian, I assume you're using a 16 ohm internal speaker. That will not work on the strobe output. You could try wiring a resistor in series with the speaker to drop the volume. Jim Quote
sixwheeledbeast Posted August 5, 2016 Posted August 5, 2016 On 05/08/2016 at 09:09, Jim Randle said: You could try wiring a resistor in series with the speaker to drop the volume. Jim Expand Then it will no longer be a 16 ohm speaker? Quote
datadiffusion Posted August 5, 2016 Posted August 5, 2016 On 05/08/2016 at 06:49, MrHappy said: wow, welcome to the yr 2000..... or there abouts Expand It's worse than that, no doubt could have been fixed for £1.99, probably the NVM chip... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
datadiffusion Posted August 5, 2016 Posted August 5, 2016 (edited) On 05/08/2016 at 01:11, bazzacool said: Hi I have a Scantronic 9800 and just updated to 9800+ after main board failure. All ok except the internal sounder is deafening on alarm set. The volume control does not alter it and there does not seem to be a setting that will allow just key pads to bleep only. Is there a setting to turn off the internal sounder on a set but activate on an alarm? I cannot see a setting in the manual that would cover this. If there is not a setting to do this can I run the sounder off the strobe circuit so it only activates on alarm? Thanks Adrian ] Expand IIRC the entry exit tone volume control on the 9800+ was moved to a trim pot on the PCB itself, rather than a programming function. This was IIRC a Bodgy McBodge to enable the former command 28 to be reused to enable or disable 'hide status' in the day mode, or something like that... The old 9800 would merrily tell any burglar that could see it that 'Day' mode was in use and it was OK from a risk to employment status PoV to break in. The volume will always 'go up to 11' on a real alarm, regardless of the EE volume, I believe. Edited August 5, 2016 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
bazzacool Posted August 6, 2016 Author Posted August 6, 2016 Many thanks to you all for making me focus on the pot. It suddenly dawned on me that the test sounder feature used full volume and I would need to set the system to hear the real volume (not alarm). After a few tries set it at just above zero and sounder is now tolerable, Thanks again Adrian ps Yes I may be stuck in year 2000 but I can wire and programme the 9800/9800+in my sleep and while there are still spares around it does work fine. Quote
MrHappy Posted August 6, 2016 Posted August 6, 2016 On 06/08/2016 at 21:27, bazzacool said: ps Yes I may be stuck in year 2000 but I can wire and programme the 9800/9800+in my sleep and while there are still spares around it does work fine. Expand used or new old stock via fleabay, Quote Mr Veritas God
james.wilson Posted August 7, 2016 Posted August 7, 2016 it is odd why people upgrade to 20 year old stuff. Its a good job it not doing anything important like protecting... btw I have a load of 30 yr old airbags for vw's. Sold as seen get in quick Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted August 7, 2016 Posted August 7, 2016 I'd rather have a 20 year old scantronic than some modern 1 way wireless tat. All about the risk? Seems like a simple swap like for like, it's the same reason obsolete keypads sell well on ebay. Very easy to swap something like for like, although I have known "engineers" to get this wrong. Quote
