james.wilson Posted September 14, 2016 Posted September 14, 2016 not just me then? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
petrolhead Posted September 14, 2016 Posted September 14, 2016 I take offence. I worship fsm and his noodly appendages Quote
datadiffusion Posted September 15, 2016 Posted September 15, 2016 Burn the witch ^^^ Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
datadiffusion Posted September 15, 2016 Posted September 15, 2016 On 14/09/2016 at 20:55, Keighley said: Thank you MrHappy and sixwheeledbeast I will be ordering a battery tomorrow before I do any more to the alarm again thank you all Only 101 days to Christmas!!! Expand Avoid the 'chanfa' brand and similar on ebay. If you have a toolstation near you they keep approx one or two Yucell 7ah on the shelf at any one time. Yuasa or Genesis are good (and there are other decent ones) but if you want it quicky toolstation is handy... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Keighley Posted September 15, 2016 Author Posted September 15, 2016 ordered a Yuasa 7amp off amazon £15 in delivery Just finished fitting all new PIRs and programing so now got 8 door contacts and 5 PIRs, thank you all probably saved me a fortune by the way I removed the battery which was very hot opened it up and persevered and toped all the cells up, refit tops and glued now battery holding charge and staying cool so will prob have a spare battery when new one comes. another thing I did was drill a small hole in the side of the panel and extend the battery leads so I could monitor the battery with the panel lid back in place, so looks like everything is ok now (I will put the battery back inside when I'm satisfied all is 100% ) Thank you all for being assistance and may all your problems be small ones Quote
datadiffusion Posted September 15, 2016 Posted September 15, 2016 On 15/09/2016 at 21:58, Keighley said: by the way I removed the battery which was very hot opened it up and persevered and toped all the cells up, refit tops and glued now battery holding charge and staying cool so will prob have a spare battery when new one comes. Expand If you take one other piece of advice, please, bin the old battery and fit the new one! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
MrHappy Posted September 16, 2016 Posted September 16, 2016 Alarm batteries are lead acid gel batteries, I'm impressed if you've manged to top one up with water.... Quote Mr Veritas God
Keighley Posted September 16, 2016 Author Posted September 16, 2016 yes you have to put small amounts in and just tap lightly the internal mat to get all the air out (use a cotton bud with the cotton removed and to put water in use a striped down pen, thumb over end then release water I was brought up in the era when you repaired everything Quote
al-yeti Posted September 16, 2016 Posted September 16, 2016 On 16/09/2016 at 15:25, MrHappy said: Alarm batteries are lead acid gel batteries, I'm impressed if you've manged to top one up with water.... Expand Judging by the small holes etc he's read one of your gashing posts Although I wonder how long it will be before that battery catches fire , lead acid battery in an alarm panel???? Or drilled into a gel one , hardcore 1 Quote
