Hi, I am looking for help please. I have installed the above alarm at home and have a problem. I am getting the fault code ' Tamper Fault Lockout' I suspect the issue is with the bell box as everything else looks to be ok. It is a Honeywell AG6 Bell Box and when installing there was a sheet inside the box saying to wire differently to the installation manual. I have also tried another wiring diagram I found on a previous post n here but still no joy. It appears that there is only 1x tamper wire coming back from the bell box - Is this correct? I have the following terminals n the bell box - TR-, S-, V+, V-, ST- Can anyone confirm to which the T A D B wires from the control panel should go to?
Also any other ideas welcome. I have checked the tamper circuit from the Keypad and the PIR's and they are both ok and I have removed the auto dialler for now.
Any help would be much appreciated as I am all out of ideas.
Regards
Dave
Edited by Dave S
yes link t to a. Disconnect all the san wiring first and while powered down etc
Register a new account
Sign in
