Hi
The system is based around a Scantronic PD9651 with four Honeywell IS312 PIRs with fsl wiring. It was installed around four months ago and has been operating properly until now.
Last night a false alarm condition occurred after the system had been fully set for about a week. The relevant part of the log reads:
22.07.06 Burg Z04 Alarm
22.07.09 Burg Z04 Restore
22.10.23 Burg Z04 Alarm
22.10.26 Burg Z04 Restore
22.25.24 Z04 Lock Out
22.25.24 System Rearmed
I have checked the connections inside the PIR and all appear to be good and tight and the resistor legs appear to be sound and not crossed. Nonetheless, I have given the screws an extra tweak.
Very close to the PIR I did, however, find quite a large spider. Could it have been the cause of this particular false alarm? If not, as usual, any suggestions/comments would be most welcome.
Many thanks.
24 minutes ago, PeterJames said:
Was there any signs of a spider? Cobewebs? Spider close by?
Quote
9 minutes ago, datadiffusion said:
Tat will teach me to only read the first few lines.
Yes a spider on the detector will look like an elephant in the room
Thanks for all the interest/feedback so far.
I had heard that spiders could cause issues but jut wasn't sure if they could cause the alarm/restore/alarm/restore pattern shown in the log.
2 hours ago, Nova-Security said:
Didn't know such stuff existed! Will get hold of some asap - prevention won't do any harm.
28 minutes ago, datadiffusion said:
You can get it on Amazon and it does seem to work
Good to hear. Can also get it from Lakeland - just been out and got some there.
