Titch007 Posted October 1, 2016 Posted October 1, 2016 Hi all, Just moved into a property which has abacus alarm system installed. One of my lil ones decided to press the panic button and now the alarm will not set. I've tried resetting but on reading some posts on the forum I'm aware I need to reset the panic button. The question is how do I do this? Do I need a special key? Any help will be greatly appreciated!! regards T Quote
satsuma01 Posted October 1, 2016 Posted October 1, 2016 there should be a key left by the unit or with you from the owners, if not pm me your address and ill send one in the post, a small shaped keyhole on the unit is where the key fit and you just twist the key to push the trigger button back to break the contact. Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Jim Randle Posted October 1, 2016 Posted October 1, 2016 If your panic button looks like this, you can undo the two screws, take the front off and push the buttons back with your finger. Quote
sixwheeledbeast Posted October 1, 2016 Posted October 1, 2016 13 minutes ago, Jim Randle said: If your panic button looks like this, you can undo the two screws, take the front off and push the buttons back with your finger. You can damage a new type CQR PA if you remove the lid while triggered Quote
sixwheeledbeast Posted October 1, 2016 Posted October 1, 2016 3 hours ago, Titch007 said: Just moved into a property which has abacus alarm system installed. One of my lil ones decided to press the panic button and now the alarm will not set. I've tried resetting but on reading some posts on the forum I'm aware I need to reset the panic button. Have you tried to contact the installer they maybe able to supply the key for you as there are a few different types. Quote
Jim Randle Posted October 1, 2016 Posted October 1, 2016 Mr Beast is right. I should have remembered. The older one's are OK to open. Jim Quote
al-yeti Posted October 1, 2016 Posted October 1, 2016 Yes take cover off , hope it's not engineer reset or something crazy Quote
firemonkey Posted March 9, 2017 Posted March 9, 2017 As its an Abacus system, it will most likely be a very old PA button, so taking it apart to reset and put back together and then enter your code to reset system. Quote
