ElecTech Posted October 2, 2016 Posted October 2, 2016 Guys - quick curious question... What is it within a monitored maglock that determines the light to go either green or red? I had a door that seemed lock but didn't turn green, when it grabbed tighter to the magnet the light turned green which is correct. I was just wondering what mechanism it uses within the maglock to determine if it is fully secure or not. Quote
Nova-Security Posted October 2, 2016 Posted October 2, 2016 Its called Hall effect Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Rulland Posted October 2, 2016 Posted October 2, 2016 The led should go red when the mag is engaged, not green, green unlocked, red locked. The armature needs to be the right way round to use the 'hall' effect there is a dimple on the armature that needs to be closest to the electrical connection end on the mag for it to work correctly. Quote
ElecTech Posted October 2, 2016 Author Posted October 2, 2016 38 minutes ago, Rulland said: The led should go red when the mag is engaged, not green, green unlocked, red locked. Not on the locks I use... Red unlocked, green is engaged. Quote
datadiffusion Posted October 2, 2016 Posted October 2, 2016 Just fitted one and can confirm on mine (these are from AA access 'own brand') green when door closed and energised, red when energised but door still open. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Nova-Security Posted October 2, 2016 Posted October 2, 2016 1 hour ago, Rulland said: The armature needs to be the right way round to use the 'hall' effect there is a dimple on the armature that needs to be closest to the electrical connection end on the mag for it to work correctly. Does not matter for sensing the amature, the dimple you'r on about is a spring is designed to push the amature off the lock when no power to lock, and is to be fitted furthest from the door hinge. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
J&D Security Posted October 3, 2016 Posted October 3, 2016 http://www.electronics-tutorials.ws/electromagnetism/hall-effect.html Quote janddsecurity@live.co.uk
datadiffusion Posted October 3, 2016 Posted October 3, 2016 Electronic replacements for car distributors often used hall effect to replace contact breaker too (younger readers may be wondering wtf a 'distributor' is I bet...) Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
