melcom st6000
Guest bramwec
Guest bramwec
sorry completely no idea what im doing but can anybody tell me how to change my security code on the melcom st6000 as I have lost the manual please ?
This manual can be downloaded from
http://groups.msn.com/UKSecurityPanels
ST6000 - USER INSTRUCTIONS
TO SET THE ALARM:-
Enter your four digit code
TO UNSET THE ALARM:-
TO PART SET THE ALARM:-
Enter your code and press 'set'
TO SILENTLY SET:-
Press 'Prog' during exit time
TO OMIT A ZONE/S:-
Press 'Omit' during the exit time,
then the zone numbers, then 'Set'
TO RESET DURING/AFTER AN ALARM:-
Enter your four digit code and press 'Reset'
CUSTOMER PROGRAMMING
TO TEST SYSTEM, SOUNDERS AND STROBE:-
Press 'Prog' and enter your four digit code
Then press '0'
Press '1' to test the strobe, 0 to stop
Press '2' to test the outside sounder, 0 to stop
Press '3' to test the high volume internal sounder, 0 to stop
Press '4' to test the low volume internal sounder, 0 to stop
Press '5' to walk test the system, 0 to stop
To exit test mode press 'Reset'
TO CHANGE CUSTOMER CODE:-
Press 'Prog' then your four digit code, then press '8'
Enter your new four digit code
Guest Adrian
B) Why bother its the same as the earlier ADE optima panels
Adrian B)
  • 4 years later...
