Hi
I'm new to this forum so be gentle!:D
Having been away from installations for a couple of years, I'm back doing a Galaxy 2-20 installation for a related family business.
However, I'm looking for a steer on the SMS signalling. Previous 2-20 installations that I have done were ARC only, not using the SMS option. I understand that this is a secondary notification should the primary ARC fail. However this will not have ARC comms, so I'm setting this up with the Comms Fail Time for the ARC set to a minimum, so that it will go straight to SMS notification to the 3 numbers allocated. This is primarily to advise the owner of set/unset notification and intruder activation.
I'm looking to get a SMS centre number that will work. If need be that can be a subscription service, but not sure where to look for this information.
Any info gratefully received...thanks
Posted (edited)
Hats off to SPC, they use ETSI, not the terrible TAP - ETSI is actively supported by BT and the texts are sent and arrive in approx 2 seconds, even on an ADSL line.
I can't work out why other manufacturers don't use this format??
Edited by datadiffusion
At least the BT service is ~10p per UK SMS.  1/5 of the OpenTAP price per message.
Hi Guys,
Many thanks for the post with information...much appreciated.
Just to follow up with GalaxyGuy & datadiffusion, how do I get to use the BT service?
This seems to be a cheaper and more reliable option.
Is the 2-20 panel compatible with the BT service?
Thanks
Posted (edited)
  On 10/10/2016 at 10:15, jg999 said:
Hi Guys,
Thanks
Expand
You don't :(
BT supports only the far superior ETSI protocol which for some odd reason panel manufactures don't appear to use, but most consumer DECT phones and the Siemens SPC panel do.
Edit - and HKC it would seem...
  On 10/10/2016 at 10:52, james.wilson said:
only etsi panels I know are the spc and the hkc
Expand
Which is mad, I can't believe it's a huge problem, surely a software thing? Interesting though, two RoI designed panels...
