Greenveg Posted October 10, 2016 Posted October 10, 2016 Hi, I have a Scantronic Burglar Alarm. The code buttons are getting a bit worn, which makes it difficult to enter the code. I have changed the code a couple of times, so I can press buttons that have not had as much wear. I can acquire a control panel to replace the existing one. Is this a job that I could do myself, or is there a lot of re-wiring involved. Regards. Quote
datadiffusion Posted October 10, 2016 Posted October 10, 2016 What model do you have now? If you get stuck point us to a picture of a similar keypad on google images etc... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Greenveg Posted October 10, 2016 Author Posted October 10, 2016 Sorry, I should have said originally, it is a 9448. Quote
datadiffusion Posted October 10, 2016 Posted October 10, 2016 You can still buy this model, Scantronic are now owned by Eaton, they still use 'Scantronic' but badge 'low end' models as 'Eaton' now, such as the 9448 and i-On 16 However, your best bet would be to buy a Scantronic 9651, as you'll gain an LCD (separate) keypad, and it comes with full instructions. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Greenveg Posted October 12, 2016 Author Posted October 12, 2016 Would the 9651 allow me to keep keep the existing wiring around the the rooms which are alarmed, and the alarm box outside, and connect from the 9448 to the 9651. Quote
datadiffusion Posted October 12, 2016 Posted October 12, 2016 You would ditch the 9448 completely. The 9651 comes with the main box and a separate keypad that can be mounted anywhere. You could keep everything else; however, it does sound as if you might be better off getting someone in to do it for you. The biggest benefit of getting someone in would be that they can change the tamper wiring over from 'global' to EOL, i.e one tamper circuit per device, this would be without changing the wires to the detectors. Also if you get someone in they can advise you if you need a new system battery (highly recommended) and check the bellbox etc... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
