Regards the bells - I am connecting up an X-BE bell, wired. So I assume i connect this up as per normal - tamper ring, strobe and bell negative returns and the 12v feed.... I am also connecting an Odyssey wireless - let the system learn this device as usual.
My question is (assuming everything above is ok) - Would i bother to assign them as SAB and SCB respectively? I gather not as the current draw from the panel is no longer an issue, given that one of the devices is wireless.
If i were to ever convert this to wired for the second box - I assume the SAB/SCB is a switch option inside the bell box itself?
SCB can sometimes, very occasionally be of use, I've used it precisely zero times in 20 years!
If I'm ever fitting 2 SABs because of low bell height, chance of attracting neighbours at the back etc... then I just up the PSU.
Yes wireless bell is, well, just that so no settings to worry about.
If you have a single wired bell, SAB is the way to go.
  • Upvote 1
3 hours ago, 1animal1 said:
Noted.... £23.50 for what?
well £28.99 inc vat is the price difference between buying the ebay item & buying it on a 14 day offer at "trade price"
So for premium of £28.99 I can have upto 48 days credit & pop into my local branch & collect stock or normally next working day if not in branch stock...
  • Upvote 1
Is SCB simply a switch option then in the box?
I've always assumed there was a good mark up - not least because when i was about to buy a Pyronix system, the chap was able to supply 2x new pirs and 2x door contacts for £65.... Where as i don't need to tell you the online cost.
Posted (edited)
Yes, usually. Or a wire link, or jumper etc...
Though I note with the very latest Elmdene Quartz backplates (the bells I use) we have gained an NiMh battery (rather than NiCad), lost a xenon tubed strobe and gained an LED strobe, and lost SAB/SCB mode altogether...
Edited by datadiffusion
I think the loss of SCB is because no-one is using it. The LED probably takes about the same as the strobe did tbh.
I always thought xenon strobes needed a larger capacitor to provide the end required light compared to an equivalent LED? - used to be a lighting engineer moons ago ;)
Flash rate was less than 1Hz though, and no doubt they've not held back on the freq. nor current rating of the LEDs, 6 @ 20mA even will be similar.
Strobe was always guesstimated at 80-120mA AFAIK on a system, same as a keypad tbh.
https://www.tlc-direct.co.uk/Technical/DataSheets/Ade/TSRESON8_Install.pdf for an example
This topic is now closed to further replies.
