Or if you are going to use the app and remotes, just locate the panel elsewhere. OR you can hardware a keypad into the panel....if you can find a sensible route for the cable, ideal.
The wireless arming station is a bit pants to look at IMO
i like the idea of just the fobs - the worry is the fobs not offering 3 programs, but then i guess the app can be used where the fobs cannot?
On another note - how expensive are the PIR's! £40 each... :o different to the £5 jobbies i've fitted in past houses - admittedly wired.
Thanks for all the replies so far.
I'm not after cheap - i just want the best for my money - I don't want to pay extra if all I'm getting is something trivial. When i sourced my cameras i noticed you can easily spend a fortune and easily end up with rubbish. ;)
This topic is now closed to further replies.
