Posted (edited)
Edit - having re-read you can indeed select multiple attributes. The devil is in the detail!
I presume it doesn't matter that I've changed the part set settings via the part set menu?
Edited by 1animal1
Swb, do you happen to know how long the settings and learnt devices are saved when battery and mains are withdrawn?
I've got an IP board, remote panel and two more pirs (wired to remote)to wire in, in the next week. I didn't want to start setting users etc up if it'll all likely disappear.
Posted (edited)
Thanks chaps....
I've now got all the wireless stuff fitted - still have bell tamper and aux tamper showing for the X-BE bell - although I'm still to activate the battery in the box and finish commissioning instructions (Global options). That said it sounds like i need to omit these via the panel as the X-Be only has 5 contacts - Tamper,bell, strobe, 0v and 12v... where as other models appear to have a tamper circuit additionally.
Edited by 1animal1
What you in about dude?
What you mean there's no bell tamper? In the bell or what your looking at on the panel
Yep Grade 2 Premier sounder - the new X-BE. It only has those 5 contacts and then 2 additionals which i read, should be left alone with MSW written across them
This topic is now closed to further replies.
