I agree, we're mere mortals.
This has come about as I still have an auxiliary fault and bell fault on the panel. Siren showing left LED flash which indicates open tamper circuit
28 minutes ago, 1animal1 said:
Do I need to short the bell tamper at the panel.
I can only assume you mean the "AUX TAMP", this will need to be closed if you are not using it for axillary equipment.
Tamper protection is an important part of alarm systems, linking any "bell tamper" that is used will stop the alarm triggering if the bell is attacked.
  • Upvote 1
7 minutes ago, 1animal1 said:
Thanks, so because my bell is grade 2.... It's less protected. What is the single tamp for that's in the five cables....
Grade 3 specification have extra requirements for higher risk sites.
The bells are also designed to work with other manufacturers kit, so extra tamper terminals are provided on Grade 3 boxes if you need trigger wire monitoring and all that jazz.
  • Upvote 1
12 minutes ago, james.wilson said:
dont worry about grade 3. You cant do it without proper signalling anyway. As a self install you will do well to hit grade 2
One day I might
  • Upvote 1
This topic is now closed to further replies.
