1animal1 Posted November 12, 2016 Author Posted November 12, 2016 (edited) I'm on it Al! Just want to check im not going to make a silly mistake. These two wired pirs... I've set them for Eol wiring. Presume from the below I wire alarm, tamper and then the power to the + - terminals on the network.... And leave fta and rled Edited November 12, 2016 by 1animal1
al-yeti Posted November 12, 2016 Posted November 12, 2016 Does it have built in eol? Otherwise you need resistors, get all power correct and switch it on and hope for the best , and post the faults
1animal1 Posted November 12, 2016 Author Posted November 12, 2016 Yep built in Eol. I bought the correct resistors just in case.... Just putting everything in place to add this final part to the system. Then to configure the ip Currently no errors after looping off the bell aux, and turning the battery to on in the wired box.
1animal1 Posted November 13, 2016 Author Posted November 13, 2016 And the latest... IP up and running, just need to link it to the app. Although no huge rush due to the app being a bit rubbish by all accounts. I'm also getting a bit of drop out when connecting remotely on the LAN. Remote keypad installed along with two wired pirs. Only issue was the 4k2 mode, neither would detect so I moved them back to default Eol as per texecom spec... Problem resolved. Only issue now is not being able to get the front door chime working. It's turned on in options, volume up but still no chime.... Wondering if it's part of the area options. I also need to check all part sets without setting the sirens off.... Will hold off mode allow me to do this?
al-yeti Posted November 13, 2016 Posted November 13, 2016 Thought hold off was for tampers , just dis the bell trigger temporarily Or maybe there's an option for internal bells only on part set like a 9651
sixwheeledbeast Posted November 14, 2016 Posted November 14, 2016 press the chime button on the keypad hold off mode will be cancelled on bell trig, best to remove trig wire for testing
1animal1 Posted November 14, 2016 Author Posted November 14, 2016 Thanks chaps Will attempt the bell later. Regards the hold off... I have a wired and wireless bell, so the trigger removal would only cure half the problem. I'm sure I'll be able to get the parts tested on Saturday day with a few short alarms.
lymebayalarms Posted November 14, 2016 Posted November 14, 2016 Remove the trigger for the hardwired. Delete the other bell and relearn when the testing is complete. 1
1animal1 Posted November 15, 2016 Author Posted November 15, 2016 Thanks swb, door chime working a treat. Lyme... Due to the hassle of getting the ladders out again. Think I'm going to go for a soak test during the day to spot any major issues whilst I'm at work, then do some midday Saturday testing of the part arms... It won't take many trips of the part arm to suss out it all works as programmed I've also since turned off the function that means an engineer can only reset any alarm trips... Adjusted timers and clock... Anything else I should be looking at that's glaringly obvious? Other than that I think I'm getting there! The IP I can use fully remotely on the LAN via laptop or app (whilst on the WiFi network). I started setting up the ARC and created an account but unsure what use this will be once they've sorted their app out? Speaking of which, can't connect remotely by the app yet so might have to revisit the port forwarding - 99% it's set right... More playing required.
sixwheeledbeast Posted November 15, 2016 Posted November 15, 2016 Read up about port scanners like nmap or there are web ones. I believe you will be able to copy the setup details into the new app and job done. The app maybe be more flaky if the COM-IP can't connect to the web. Make sure you have correctly followed ALL the instructions for the COM-IP they are tricky to setup for some, I know "engineers" that struggle with them. Use SIA and SIA Text for ARC config for best push results.
