Ack1234 Posted October 27, 2016 Posted October 27, 2016 Hi does anyone have Adt master codes or know how to factory reset a domonial system thanks Quote
norman Posted October 27, 2016 Posted October 27, 2016 Yes thanks, next question. Quote Nothing is foolproof to a sufficiently talented fool.
Ack1234 Posted October 27, 2016 Author Posted October 27, 2016 So that means can't give out with your smart **** answer Quote
J&D Security Posted October 27, 2016 Posted October 27, 2016 You've asked for two things which are against the forums rules. No defaulting info, or codes 1 Quote janddsecurity@live.co.uk
PeterJames Posted October 27, 2016 Posted October 27, 2016 Ive heard if you leave the PCB in the freezer overnight it defaults to 1234 Quote
norman Posted October 27, 2016 Posted October 27, 2016 54 minutes ago, Ack1234 said: So that means can't give out with your smart **** answer Sorry, no Idea what that means? Quote Nothing is foolproof to a sufficiently talented fool.
lymebayalarms Posted October 27, 2016 Posted October 27, 2016 23 minutes ago, PeterJames said: Ive heard if you leave the PCB in the freezer overnight it defaults to 1234 You need to fill the panel full of water first, once frozen ensure cold start procedure is followed ;-) 2 Quote
Ack1234 Posted October 27, 2016 Author Posted October 27, 2016 Get the message just a diy thing . 1 Quote
PeterJames Posted October 27, 2016 Posted October 27, 2016 1 hour ago, lymebayalarms said: You need to fill the panel full of water first, once frozen ensure cold start procedure is followed ;-) Do you have to defrost it before you power it up? Quote
al-yeti Posted October 27, 2016 Posted October 27, 2016 Domonial not worth the hassle either way just bin it Quote
