27 minutes ago, Simon maddox said:
What should I do?
Become Batman & fight injustice ?
or try a different telly / vga or composite video input ?
Log into its webpage & select a lower HDMI resolution ?
  • Thanks 1
It will have display settings in the menu, but you need to plug it in to  a tv with a higher resolution in order to get to the menu. I would do that before buying a new TV you may find you just have a dodgy HDMI lead or DVR
9 minutes ago, datadiffusion said:
Sounds like Pete has a Floureon system at home ;)
More or less
Ive got piles of old tat that Ive ripped out and replaced, I use it to demo the rubbish over the good stuff  I counted 20 different brands from Anke to Swann in our test room, many have the same pcb different firmware
You are wonderful
I look up to you and think you are great
