Titch007 Posted November 7, 2016 Posted November 7, 2016 Hi all, Another issue with my alarm. On searching on the forum, I understand that a TRBL POWER fault on the DA system Abacus is due to a faulty battery. Just wondering if I remove the cover to find out what battery to get, will all hell break lose? I've not reset the system or set it as I fear the internal sounder will just go off for hours. I just moved into this property and been left with no manuals etc. I have no engineer codes either, just the master code. I'm assuming that if I undo the cover on the box, a tamper fault will register. Do I just switch the battery and reset the system with the master code? Or is this a job for the professionals? Any advice will be greatly appreciated. thanks in advance, Titch Quote
lymebayalarms Posted November 7, 2016 Posted November 7, 2016 If you don't know the code, call in the Pro's Quote
Amps Posted November 7, 2016 Posted November 7, 2016 2 hours ago, Titch007 said: Hi all, Another issue with my alarm. On searching on the forum, I understand that a TRBL POWER fault on the DA system Abacus is due to a faulty battery. Just wondering if I remove the cover to find out what battery to get, will all hell break lose? I've not reset the system or set it as I fear the internal sounder will just go off for hours. I just moved into this property and been left with no manuals etc. I have no engineer codes either, just the master code. I'm assuming that if I undo the cover on the box, a tamper fault will register. Do I just switch the battery and reset the system with the master code? Or is this a job for the professionals? Any advice will be greatly appreciated. thanks in advance, Titch Trbl Power is also the message for AC fail. Try to set the system with the master code then unset the system and if it is AC failure and the AC has restored the panel will be reset. Quote
al-yeti Posted November 7, 2016 Posted November 7, 2016 Is it a metal box , or plastic box ? Different size batteries Quote
Titch007 Posted November 7, 2016 Author Posted November 7, 2016 Thanks for the responses guys. So I'll definitely need a engineer code to change the battery even though I have the master? I managed to download a copy of the Abacus manual and it said if it was an AC fault the code TRBL SUPPLY. I reset the system. The TRBL power code disappeared but after 5mins the interval bell went off again with the same fault code. The box is metal. Has anyone got any idea which battery is standard or best? Quote
PeterJames Posted November 7, 2016 Posted November 7, 2016 1 hour ago, Amps said: Trbl Power is also the message for AC fail. Try to set the system with the master code then unset the system and if it is AC failure and the AC has restored the panel will be reset. Im sure it says trbl mains if its mains Quote
al-yeti Posted November 7, 2016 Posted November 7, 2016 What you mean interval bell? You mean it just started beeping on internal speaker with the high tone? That will be the battery You got nothing to lose , just put new battery in , if it's engineer reset you will have to call someone out , ask them to make it user reset Quote
Titch007 Posted November 7, 2016 Author Posted November 7, 2016 Sorry, that's auto correct. I meant internal bell. Cool, I'll give it a go in the morning. Don't want to wake the entire neighbourhood up triggering the main alarm! Thanks for the help! Quote
datadiffusion Posted November 7, 2016 Posted November 7, 2016 46 minutes ago, al-yeti said: 12v 7ah will fit if it's the metal end Or the plastic with a hacksaw... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
