Hi.
Have bought a new Yuasa 12v battery for inside my Abacus panel.
Is it just a case of unplugging the old and plugging in the new in Engineer mode?
Not sure about it affecting programming etc.
Thanks.
If you have the engineer code, yes things are much simplified, although we always warn about the mains
voltages present in the panel, etc...
I would also check the battery again in a day or two to make sure it is actually charging.
Nope, all alarms have an NVM of some kind or another (although one day, anything between 10-25 years I guess, this will eventually fail itself as in the 9800 etc...)
Besides a trained installer would usually leave the mains running anyway - although we can't recommend 'working live'.
1 hour ago, al-yeti said:
Abacus not known for losing memory, although I can't rember
There was a problem with the 6p where it used to forget the user code, but that was only when it was set
No, none of them are probably quite old enough yet I guess, our 9800 went at only just 12 years old but I know that was a specific 'wire eprom' issue.
