sixwheeledbeast Posted December 22, 2016 Posted December 22, 2016 You shouldn't break neutrals for anything! I imagine using a relay from a programmed output to trigger the emergency stop input? Why not a lockable isolator? 1 Quote
Mattmasters Posted December 22, 2016 Author Posted December 22, 2016 they dont want to have anything to do with the shutter side.. all they want to do is turn the alarm on and know the door is isolated... i was going to use a relay to break the common live that goes to the remote.. the remote has three wires.. Common live, up and down..... either the common live or the up... maybe the up... that way it can still come down... hmmm... so many options.. Quote
al-yeti Posted December 22, 2016 Posted December 22, 2016 40 minutes ago, whistle said: 10 amp relay, diode? Open close output i would stick to house bashing. He is lol Quote
al-yeti Posted December 22, 2016 Posted December 22, 2016 3 minutes ago, Mattmasters said: they dont want to have anything to do with the shutter side.. all they want to do is turn the alarm on and know the door is isolated... i was going to use a relay to break the common live that goes to the remote.. the remote has three wires.. Common live, up and down..... either the common live or the up... maybe the up... that way it can still come down... hmmm... so many options.. You will also have to think about faults , with a fault he can't open the door at all, so you will still need some kind of override feature ,with the obvious secondary door access or manual shutter pull and so on Basically possible to do with other problems to go with it Quote
Mattmasters Posted December 22, 2016 Author Posted December 22, 2016 the fault bypass i was going to use was a tampered keyswitch.. Quote
al-yeti Posted December 22, 2016 Posted December 22, 2016 1 minute ago, Mattmasters said: the fault bypass i was going to use was a tampered keyswitch.. Could I electrocute it and blow the panel and box and coms in one go? Quote
datadiffusion Posted December 22, 2016 Posted December 22, 2016 (edited) That'll teach any burglars a lesson they won't forget... With the added bonus you can catch up with URN paperwork back at the station. Edited December 22, 2016 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Mattmasters Posted December 22, 2016 Author Posted December 22, 2016 if you want too im sure you could yes.. the door controller is only 24v but hey.. if you hold on to a near by 230v socket with wet hands u may do!! Quote
datadiffusion Posted December 22, 2016 Posted December 22, 2016 # underneath the arches # Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
