Brian c Posted October 25, 2004 Share Posted October 25, 2004 I've been given a load of ISDN to PSTN modules to fit. The programming form tells me to use a touchphone to program the MSN number (I have all the relevant MSN numbers). On the module there is a rj45 and a rj11 connector. rj11 obviously for analogue line and programming. It's a 12V module and needs to be powered (but not connected to ISDN)to program it. So, I powered it and connected a household touchphone that I know was working(I don't have a block phone at the moment), and was unable to program it or get tones from phone. I then tried with a powered phone that did produce tones, but was still unable to program the MSN number (it should produce a confirmation tone). I also treid another module. Anyway, a few questions; Does anybody know if I need a test phone to program this or should any tone phone work? Also, what is a MSN number (what does it stand for)? How many MSN number can be used on a ISDN line(is it one on each 64k line)? Thanks in advance If you don't know......ask. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/4077-isdn-lines/ Share on other sites More sharing options...
Guest Guest Posted October 25, 2004 Share Posted October 25, 2004 Pm Smart1 he has the knowlege;) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/4077-isdn-lines/#findComment-29314 Share on other sites More sharing options...
